Introduction
If you have an issue with your speaker as stated in our troubleshooting page ( HTC One M7 Troubleshooting ) then this guide is for you.
Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel. Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel. Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
Ajouter un commentaire
Pry the back loose and lift. The back panel will come off with time.
  • Pry the back loose and lift. The back panel will come off with time.
Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
  • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
  • Remove the tape gently to find some hidden screws underneath.
Use tweezers to get underneath the motherboard to lift.
  • Use tweezers to get underneath the motherboard to lift.
  • Lift gently because the motherboard is not completely disconnected.
Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
  • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
  • Lift the camera from the bottom of the motherboard.
Remove the motherboard completely out of the phone. May stay attached from one end by tape.
  • Remove the motherboard completely out of the phone.
  • May stay attached from one end by tape.
Use the blue opening tool to pry the battery from the frame. Some force will be needed since the battery is glued to the frame.
  • Use the blue opening tool to pry the battery from the frame.
  • Some force will be needed since the battery is glued to the frame.
  • Be careful to not break the battery upon removal.
Completely remove the motherboard. Completely remove the motherboard. Completely remove the motherboard.
  • Completely remove the motherboard.
Remove the #000 screws around the speaker that are located at the bottom of the frame. Lift the speaker out of the frame.
  • Remove the #000 screws around the speaker that are located at the bottom of the frame.
  • Lift the speaker out of the frame.
16 autre(s) ont terminé cette réparation.
Alex
Membre depuis le 23/09/2014
664 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 12-1, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 membres
7 tutoriels rédigés
Ok I will good
Raguraman - Réponse
Where to buy speaker???
bharatdshmkh - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 33
30 derniers jours : 128
Total : 17,374
