Aller au contenu principal
HTC Rezound Screen Replacement
Ce dont vous avez besoin
  1. HTC Rezound Screen  Replacement, Battery: étape 1, image 1 de 1
    • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
  2. HTC Rezound Screen  Replacement: étape 2, image 1 de 1
    • Remove the red battery to replace.
  3. HTC Rezound Screen  Replacement, Screen: étape 3, image 1 de 3 HTC Rezound Screen  Replacement, Screen: étape 3, image 2 de 3 HTC Rezound Screen  Replacement, Screen: étape 3, image 3 de 3
    • Unscrew the six screws (Torx T4 size) shown in the photo.
    • Use the spudger to pry the casing off of the phone.
  4. HTC Rezound Screen  Replacement: étape 4, image 1 de 2 HTC Rezound Screen  Replacement: étape 4, image 2 de 2
    • Gently remove the casing from the phone.
  5. HTC Rezound Screen  Replacement: étape 5, image 1 de 1
    • After the red casing is removed, the following components should be visible:
    • Main Camera
    • Headphone Jack
    • Vibration moter
  6. HTC Rezound Screen  Replacement: étape 6, image 1 de 2 HTC Rezound Screen  Replacement: étape 6, image 2 de 2
    • Remove the 2 screws (Torx T7 size), which are located on the upper left and lower right sides of the device.
  7. HTC Rezound Screen  Replacement: étape 7, image 1 de 3 HTC Rezound Screen  Replacement: étape 7, image 2 de 3 HTC Rezound Screen  Replacement: étape 7, image 3 de 3
    • Using tweezers, flip the latch on the ribbon cables connecting the logic board to the screen and display. The screen and display for the HTC Rezound are likely fused to one another, so if you are replacing one you will likely need to replace both of them.
    • At this point all that's left is to insert the ribbon cables of your replacement into the same slot on the motherboard!
Bridgette Mellon
Membre depuis le 01/29/18
243 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 240
