Introduction
Hello! This should be followed if your phone is having issues with the vibration function. Please be sure to follow the steps in the screen replacement guide up to the indicated point! Have fun fixing your tech!
Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is  visible.
  • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
Ajouter un commentaire
Remove the red battery to replace.
  • Remove the red battery to replace.
Using a Torx T4 screwdriver, remove the six screws from the  six spots shown in the photo. Use a spudger to pry the casing from the phone. Use a spudger to pry the casing from the phone.
  • Using a Torx T4 screwdriver, remove the six screws from the six spots shown in the photo.
  • Use a spudger to pry the casing from the phone.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Gently remove casing from phone. Gently remove casing from phone.
  • Gently remove casing from phone.
Shown here is the vibration Monitor, this is what you will be replacing.
  • Shown here is the vibration Monitor, this is what you will be replacing.
Remove the body of the monitor from the case attaching it to the motherboard. Make sure to remove any potential obstruction that could be blocking the weight at the end! Make sure to remove any potential obstruction that could be blocking the weight at the end!
  • Remove the body of the monitor from the case attaching it to the motherboard.
  • Make sure to remove any potential obstruction that could be blocking the weight at the end!
Carefully disconnect the cable attached at the motherboard.
  • Carefully disconnect the cable attached at the motherboard.
Insert the replacement's cable into the same spot on the logic board! Then just set it back into the slot on the logic board and you are done!
  • Insert the replacement's cable into the same spot on the logic board! Then just set it back into the slot on the logic board and you are done!
Robin White
Membre depuis le 29/01/2018
133 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 40
