Aller au contenu principal
HTC Sensation / 4G / Pyramid - Touch Screen / Digitizer Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement, Touch Screen / Digitizer: étape 1, image 1 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement, Touch Screen / Digitizer: étape 1, image 2 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement, Touch Screen / Digitizer: étape 1, image 3 de 3
    • Unscrew 8x screws and remove the back cover using a plastic tool.
  2. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 2, image 1 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 2, image 2 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 2, image 3 de 3
    • Disconnect the LCD display cable and the menu buttons cable.
    • There are another two cable connector between the main board and the additional upper board.
  3. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 3, image 1 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 3, image 2 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 3, image 3 de 3
    • In case to remove the upper board, unscrew the screw and release the power button flex cable and the volume up/down flex cable.
    • In another side of the board is the touchscreen flex cable connector.
  4. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 4, image 1 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 4, image 2 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 4, image 3 de 3
    • Use hot air to warm the touchscreen.
    • With a plastic tool start to separate the touchscreen.
    • Gently release the menu flex cable from the touch screen.
  5. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 5, image 1 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 5, image 2 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 5, image 3 de 3
    • The touchscreen flex cable go between the LCD display and the upper case / housing.
    • Again use a plastic tool and hot air to free up the cable.
    • Work carefully to avoid breaking the display.
  6. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 6, image 1 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 6, image 2 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 6, image 3 de 3
    • I use toothpicks and hot air to make place for the cable of the new spare part.
  7. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 7, image 1 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 7, image 2 de 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: étape 7, image 3 de 3
6 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 278 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 528 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 4,086
