Introduction
Replacement of the HTC Touch Pro's usb logic board.
Pièces
Aucune pièce nécessaire.
Gently press on back plate, push toward camera direction. Gently press on back plate, push toward camera direction.
  • Gently press on back plate, push toward camera direction.
Ajouter un commentaire
Use finger to lift up an edge of battery. Use finger to lift up an edge of battery.
  • Use finger to lift up an edge of battery.
Remove 4 screws circled in red using T6 screw driver.
  • Remove 4 screws circled in red using T6 screw driver.
Lift plastic cover near Memory card slot. Lift plastic cover near Memory card slot.
  • Lift plastic cover near Memory card slot.
Remove two Phillips #00 screws from the backside of the screen.
  • Remove two Phillips #00 screws from the backside of the screen.
Insert a spudger or plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
  • Insert a spudger or plastic opening tool into the seam on the side of the phone.
  • Gently pry apart the two halves of the phone.
  • Work your way around the phone until the two halves separate.
Gently unplug connectors marked with blue rectangle. Remove screws circled in red with 00 Phillip screw driver.
  • Gently unplug connectors marked with blue rectangle.
  • Remove screws circled in red with 00 Phillip screw driver.
Which screws in red? There aren't any.
Calion - Réponse
They are marked up in red in the second picture.
Jake Devincenzi -
Gently lift logic board using plastic opener tool. Be aware of antenna
  • Gently lift logic board using plastic opener tool.
  • Be aware of antenna
Zhaowei Zhang
Membre depuis le 28/04/2011
112 Réputation
4 tutoriels rédigés
Équipe
CSU Los Angeles, Team 1-6, Nelson Spring 2011 Membre de l'équipe CSU Los Angeles, Team 1-6, Nelson Spring 2011
CSULA-NELSON-S11S1G6
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,899
