Aller au contenu principal
Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement
Ce dont vous avez besoin
  1. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement, Outside cover and stylus: étape 1, image 1 de 2 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement, Outside cover and stylus: étape 1, image 2 de 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 2, image 1 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 2, image 2 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 2, image 3 de 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 3, image 1 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 3, image 2 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 3, image 3 de 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement, Batteries: étape 4, image 1 de 2 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement, Batteries: étape 4, image 2 de 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 5, image 1 de 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement, Back Cover: étape 6, image 1 de 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 7, image 1 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 7, image 2 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 7, image 3 de 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 8, image 1 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 8, image 2 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 8, image 3 de 3
    • Disconnect the flex strip from the motherboard with tweezers.
  9. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement, Button Pad and Battery Terminal: étape 9, image 1 de 1
    • Use tweezers to remove the power button from the back case.
  10. Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 10, image 1 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 10, image 2 de 3 Handspring Visor Deluxe PDA Button Pad and Battery Terminal Replacement: étape 10, image 3 de 3
    • Disconnect the button pad by using the spudger to pry it off the motherboard.
    • Remove the button pad.
David Faltemier
Membre depuis le 06/20/12
19 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-2, Regan SU 2012 Membre de l'équipe Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 623
