Aller au contenu principal
Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement
Ce dont vous avez besoin
  1. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: étape 1, image 1 de 2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: étape 1, image 2 de 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 2, image 1 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 2, image 2 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 2, image 3 de 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 3, image 1 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 3, image 2 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 3, image 3 de 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: étape 4, image 1 de 2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: étape 4, image 2 de 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 5, image 1 de 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Back Cover: étape 6, image 1 de 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 7, image 1 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 7, image 2 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 7, image 3 de 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 8, image 1 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 8, image 2 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 8, image 3 de 3
    • Disconnect the flex strip from the motherboard with tweezers.
  9. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Button Pad and Battery Terminal: étape 9, image 1 de 1
    • Use tweezers to remove the power button from the back case.
  10. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 10, image 1 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 10, image 2 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 10, image 3 de 3
    • Disconnect the button pad by using the spudger to pry it off the motherboard.
    • Remove the button pad.
  11. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: étape 11, image 1 de 2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: étape 11, image 2 de 2
    • Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
  12. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 12, image 1 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 12, image 2 de 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: étape 12, image 3 de 3
    • Use the spudger to lift the motherboard from the case.
David Faltemier
Membre depuis le 06/20/12
19 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-2, Regan SU 2012 Membre de l'équipe Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 1,060
