Aller au contenu principal
Handspring Visor Edge Button Board Replacement
Ce dont vous avez besoin
  1. Handspring Visor Edge Button Board Replacement, Flip Cover: étape 1, image 1 de 2 Handspring Visor Edge Button Board Replacement, Flip Cover: étape 1, image 2 de 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Button Board Replacement, Back Panel: étape 2, image 1 de 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Button Board Replacement: étape 3, image 1 de 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Button Board Replacement: étape 4, image 1 de 2 Handspring Visor Edge Button Board Replacement: étape 4, image 2 de 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Button Board Replacement: étape 5, image 1 de 2 Handspring Visor Edge Button Board Replacement: étape 5, image 2 de 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Button Board Replacement: étape 6, image 1 de 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Button Board Replacement, Button Board: étape 7, image 1 de 1
    • Pull off front cover gently.
  8. Handspring Visor Edge Button Board Replacement: étape 8, image 1 de 1
    • Remove buttons by hand, they should come off easily.
Nick Lazarakis
Membre depuis le 01/23/11
331 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 11-28, Maness Winter 2011 Membre de l'équipe Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 757
