Pièces
Aucune pièce nécessaire.
Place Visor Edge face down. Notice the tab connecting the flip cover to the back of the PDA.
  • Place Visor Edge face down.
  • Notice the tab connecting the flip cover to the back of the PDA.
  • Gently push tab forward.
  • Do not pull on the flip cover to try and remove it from the PDA.
Ajouter un commentaire
Once flip cover is removed, turn over and remove the four 3.9 mm screws connecting the hinge.
  • Once flip cover is removed, turn over and remove the four 3.9 mm screws connecting the hinge.
Gently pull away the plastic hinge from the cover. Be careful to pull out evenly and not bend the plastic, as it can crack.The spring may also shoot out if it is not pulled out evenly.
  • Gently pull away the plastic hinge from the cover.
  • Be careful to pull out evenly and not bend the plastic, as it can crack.The spring may also shoot out if it is not pulled out evenly.
Turn the hinge piece on its side or use a screwdriver to pull out the spring.
  • Turn the hinge piece on its side or use a screwdriver to pull out the spring.
  • Reinsert new spring.
Blaize Steiger
Membre depuis le 30/01/2011
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 11-28, Maness Winter 2011 Membre de l'équipe Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 955
