Introduction
This guide will help you replace the buttons or the charging indicator. Buttons can wear out over time or stop working. Charging indicators might not light for electrical wiring reasons. A plastic opening tool and a PH0 screwdriver will be needed to remove the buttons/charging indicators.
Pièces
Aucune pièce nécessaire.
Using the plastic opening tool, to open the back panel of the device.
  • Using the plastic opening tool, to open the back panel of the device.
  • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
Ajouter un commentaire
Using the PH0 screw driver, remove the 7.5 mm screws by turning in  a clockwise direction. There are 6 screws on the front panel.
  • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a clockwise direction. There are 6 screws on the front panel.
  • Remove all of the 7.5 mm screws, by repeating the same step above.
  • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
The buttons will be on the side of the device, use the plastic opening tool to remove it from its actual place no need to use any screwdrivers.
  • The buttons will be on the side of the device, use the plastic opening tool to remove it from its actual place no need to use any screwdrivers.
Use the plastic opening tool to remove the indicator lights and replace them by new ones.
  • Use the plastic opening tool to remove the indicator lights and replace them by new ones.
yousef aljeemaz
Membre depuis le 18/10/2017
573 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G9, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 51
Total : 291
