Introduction
The safety switch must be pressed simultaneously with the operating switch for the blades to move. If the safety switch is either stuck or loose then it or its spring might need to be replaced.
Locate and remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips head #2 screwdriver.
  • Locate and remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips head #2 screwdriver.
Ajouter un commentaire
Remove faceplate, to expose inner mechanisms.
  • Remove faceplate, to expose inner mechanisms.
Locate and remove the safety switch by pulling it away from the body of device. Be careful not to lose the spring which is under pressure and might fly out during removal. Locate and remove the safety switch by pulling it away from the body of device. Be careful not to lose the spring which is under pressure and might fly out during removal. Locate and remove the safety switch by pulling it away from the body of device. Be careful not to lose the spring which is under pressure and might fly out during removal.
  • Locate and remove the safety switch by pulling it away from the body of device. Be careful not to lose the spring which is under pressure and might fly out during removal.
Inspect both the spring and switch to see if either is deformed or damaged. If so replace with new part.
  • Inspect both the spring and switch to see if either is deformed or damaged. If so replace with new part.
  • When reassembling be careful inner wires don't get caught in the spring.
Daniel Endericavillacis
Membre depuis le 25/01/2015
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 17-5, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 153
