Aller au contenu principal
Honda civic 2016 Keyless Remote Battery Replacement
Ce dont vous avez besoin
  1. Honda civic 2016 Keyless Remote Battery Replacement, Let's get started: étape 1, image 1 de 2 Honda civic 2016 Keyless Remote Battery Replacement, Let's get started: étape 1, image 2 de 2
    • Make sure to have replacement battery ready. You will need 1 pc of CR 2032 Lithium battery.
    • Remove the metal key by sliding the switch on the back of the remote and pulling the key out.
  2. Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: étape 2, image 1 de 3 Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: étape 2, image 2 de 3 Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: étape 2, image 3 de 3
    • After removing the key, you will see 2 plastic bars. This is a place where you can split the remote open.
    • The manufacturer recommeded using a coin but any hard tool or even the key itself will work as well.
    • The manufacturer recommended using a cloth covering your coin/ tool to prevent it from denting the plastic bars.
  3. Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: étape 3, image 1 de 3 Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: étape 3, image 2 de 3 Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: étape 3, image 3 de 3
    • Now you can gently pry it open
    • Removing the old battery from the left side.
    • Remember that the + side of the battery is facing up.
  4. Honda civic 2016 Keyless Remote Battery Replacement, Inserting a new battery: étape 4, image 1 de 2 Honda civic 2016 Keyless Remote Battery Replacement, Inserting a new battery: étape 4, image 2 de 2
    • Inserting a new CR 2032 battery from the right side first and then press the battery down. It should make a good 'click' sound
    • Again, make sure the + side of the battery is facing upward.
12 autres ont terminé cette réparation.
Anan Venasakulchai
Membre depuis le 12/08/18
813 Réputation
2 tutoriels rédigés
Équipe
Finn Store Membre de l'équipe Finn Store
Business
1 membre
5 tutoriels rédigés
Un commentaire
Super Anleitung mit sehr guten Fotos - vielen Dank!
Philipp Glück - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 28
7 derniers jours : 182
30 derniers jours : 961
Total : 47,179
