Aller au contenu principal
Honeytone N-10 Mini Amp Speaker Replacement
Ce dont vous avez besoin
  1. Honeytone N-10 Mini Amp Speaker Replacement, Speaker: étape 1, image 1 de 2 Honeytone N-10 Mini Amp Speaker Replacement, Speaker: étape 1, image 2 de 2
    • Flip your amp over to begin removing the plastic cover.
  2. Honeytone N-10 Mini Amp Speaker Replacement: étape 2, image 1 de 2 Honeytone N-10 Mini Amp Speaker Replacement: étape 2, image 2 de 2
    • Remove the battery cover and take the battery out.
    • Unless you want a quick pick-me-up, in which case feel free to leave it in and get shocked.
  3. Honeytone N-10 Mini Amp Speaker Replacement: étape 3, image 1 de 2 Honeytone N-10 Mini Amp Speaker Replacement: étape 3, image 2 de 2
    • Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
    • While the screws are recessed deep into the cover and difficult to see, 2-4 turns will easily release them.
  4. Honeytone N-10 Mini Amp Speaker Replacement: étape 4, image 1 de 3 Honeytone N-10 Mini Amp Speaker Replacement: étape 4, image 2 de 3 Honeytone N-10 Mini Amp Speaker Replacement: étape 4, image 3 de 3
    • Remove the back cover by carefully pushing the battery connector through the hole in the cover.
  5. Honeytone N-10 Mini Amp Speaker Replacement: étape 5, image 1 de 3 Honeytone N-10 Mini Amp Speaker Replacement: étape 5, image 2 de 3 Honeytone N-10 Mini Amp Speaker Replacement: étape 5, image 3 de 3
    • With the phillips #0 screwdriver, unscrew the two white plastic clips that hold the speaker in place.
  6. Honeytone N-10 Mini Amp Speaker Replacement: étape 6, image 1 de 2 Honeytone N-10 Mini Amp Speaker Replacement: étape 6, image 2 de 2
    • Use flush wire cutters to remove black and red wires from the old speaker.
    • Note: The black wire has already been removed in this example image.
  7. Honeytone N-10 Mini Amp Speaker Replacement: étape 7, image 1 de 3 Honeytone N-10 Mini Amp Speaker Replacement: étape 7, image 2 de 3 Honeytone N-10 Mini Amp Speaker Replacement: étape 7, image 3 de 3
    • Connect the new speaker by soldering the black and red wires to the negative and positive connections respectively
  8. Honeytone N-10 Mini Amp Speaker Replacement: étape 8, image 1 de 1
    • Connect the battery and turn the power on to test proper connection of the new speaker.
    • Some static is fine, this is the natural sound of the amp.
    • Careful not to touch any of the metal components inside while temporarily testing the connection.
  9. Honeytone N-10 Mini Amp Speaker Replacement: étape 9, image 1 de 1
    • Reverse steps 1-5 to complete repair.
    • Connect the amp to your favorite instrument and test out the new sound!
Ligne d'arrivée
3 autres ont terminé cette réparation.
Corey Brown
Membre depuis le 06/24/16
8 682 Réputation
11 tutoriels rédigés
Un commentaire
Cool. If mine doesn’t work, is it likely to be the speaker? Thanks.
hupaand - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 16
Total : 3,489
