Introduction
This Guide shows you how to replace the handle.
Pièces
Aucune pièce nécessaire.
Push the button on the top of the clean water/solutions tank and pull on the handle below the button simultaneously. The tank should easily swing out. Push the button on the top of the clean water/solutions tank and pull on the handle below the button simultaneously. The tank should easily swing out.
  • Push the button on the top of the clean water/solutions tank and pull on the handle below the button simultaneously. The tank should easily swing out.
Ajouter un commentaire
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using the screwdriver, unscrew both of the screws on the backside of the handle. Using the screwdriver, unscrew both of the screws on the backside of the handle.
  • Using the screwdriver, unscrew both of the screws on the backside of the handle.
Pull the handle upwards. It should freely slide away from the base of the machine.
  • Pull the handle upwards. It should freely slide away from the base of the machine.
Leo
Membre depuis le 22/01/2018
377 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S16-G4, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G4, Banghart Winter 2018
CPSU-BANGHART-W18S16G4
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 37
