Introduction
If your Mac laptop is running hotter then you would like, this guide will show you how to install rubber feet that will lift the laptop up to reduce your average operating temperature.
Read me: While this guide will help reduce the temperature your Mac runs at, early systems (2006-2012 MacBook/MacBook Pro) will still run hot. This is a result of Apple recycling hot air to cool these systems and not putting vents on the chassis to let this hot air escape the laptop. While this is fixed on the Retina, they are thin enough they can still trap system heat.
(MacBook Pro only) Since 13" models lack a dGPU, these systems are not as bad in terms of temperature. However, this can still be used to reduce the temperatures to a lesser degree.
The author used a Early 2009 MacBook Pro 17" for this guide. Prior to applying different feet, the system regularly ran at 180° F. After this change, the system seen a 58° temperature drop and was reduced to 122°.
Tools
No tools required.
Parts
Placing your new adhesive feet onto of the existing feet is not recommended. This may result in the factory feet coming off of the bottom of your laptop.
  • Placing your new adhesive feet onto of the existing feet is not recommended. This may result in the factory feet coming off of the bottom of your laptop.
  • Place your Macbook upside down on a clean flat surface.
  • Identify where you would like to place your new rubber feet. The ideal place to put the new feet is next to the existing feet from the factory. Avoid placing the new feet on curved edges.
  • Clean the surface of your laptop with rubbing alcohol or a similar cleaner.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Peel the paper backing off each foot. Place them in your chosen location. Peel the paper backing off each foot. Place them in your chosen location. Peel the paper backing off each foot. Place them in your chosen location.
  • Peel the paper backing off each foot. Place them in your chosen location.
Once you install the new feet, your Mac will now run cooler.
9 other people completed this guide.
Nick
40,162 Reputation
37 Guides authored
Master Techs Member of Master Techs
Community
276 Members
718 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 189
All Time: 20,955
