Introduction
Does your book have a broken spine and you don't want to spend money on a new copy? Learn how to fix the book's spine yourself in these easy-to-do instructions!
First, grab the book you would like to fix.
  • First, grab the book you would like to fix.
Ajouter un commentaire
Then, open the book to where you have the most access to the exposed inner spine.
  • Then, open the book to where you have the most access to the exposed inner spine.
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Shake up the glue before removing the cap.
  • Shake up the glue before removing the cap.
  • Then, test glue on a piece of paper before placing it on the spine of the book. It should be about the consistency of Elmer's glue.
Place the glue along the spine opposite of the cover. Make sure you are distributing glue evenly.
  • Place the glue along the spine opposite of the cover. Make sure you are distributing glue evenly.
  • You may also choose to use a paint brush to make sure area is completely covered with glue.
  • Glue is runny; use with caution.
After placing the glue, wrap the cover tightly around the book.
  • After placing the glue, wrap the cover tightly around the book.
  • Firmly drag your fingers down the spine of the book to avoid any air pockets.
  • Remove any excess glue with a tissue.
  • For the demonstration we held the book as shown. You may also choose to place something on top of the book, such as a paperweight or another book, and let it sit for 30 to 40 minutes.
After the glue is dry, you should be able to lightly tug on the pages without any movement.
  • After the glue is dry, you should be able to lightly tug on the pages without any movement.
  • If movement occurs then allow the glue an additional 10 to 15 minutes to dry. Once dry, you've completed your book repair.
2 autre(s) ont terminé cette réparation.
Britne Misner
Membre depuis le 30/09/2016
149 Réputation
1 tutoriel rédigé
Équipe
Missouri Western, Team 1-13, Adkins Fall 2016 Membre de l'équipe Missouri Western, Team 1-13, Adkins Fall 2016
MWSU-ADKINS-F16S1G13
2 membres
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 100
