Introduction
Use this guide to repair the power supply with a Phillips head screwdriver, a wrench, and pliers. These tools will help secure the screw holding the wire.
First, to remove the plastic bracket, turn toaster oven on its side.
  • First, to remove the plastic bracket, turn toaster oven on its side.
Ajouter un commentaire
Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
  • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
  • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
If the wire gets pulled out of the transformer, reinsert it.
  • If the wire gets pulled out of the transformer, reinsert it.
  • Use a small flathead screwdriver to secure the screw that holds the wire in place.
Tony Wang
Membre depuis le 05/10/2012
64 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-35, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 662
