Introduction
Sometimes cables can get in the way of the internal fan and will grind against it creating a moderate clicking sound. This guide will show how to get rid of that noise.
Start by removing the two screws on the bottom of the device as shown. Start by removing the two screws on the bottom of the device as shown.
  • Start by removing the two screws on the bottom of the device as shown.
Ajouter un commentaire
Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool. Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
  • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
  • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
Unscrew the screws from the metal shielding to remove it. Unscrew the screws from the metal shielding to remove it.
  • Unscrew the screws from the metal shielding to remove it.
How many screws are there? Can you use the re circles in the second shot to show where they are?
lkmemphis - Réponse
Move any wires out of the way of the fan so they won't grind up on it during operation.
  • Move any wires out of the way of the fan so they won't grind up on it during operation.
  • If the cables do not stay out of the way, tape them down away from the fan.
From reading the prior instructions, I am pretty sure Iknow where the wires and fan are, but in this can you use some sort of indicator? To what would you tape the wires up against the fan bearing (I think that’s what is on the right side of the fan.
lkmemphis - Réponse
Bryan Underwood
Membre depuis le 02/04/2018
697 Réputation
5 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 15
