Introduction
This guide will show you how to remove a broken or malfunctioning pedal and replace it with a new one.
Pièces
First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
  • First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
Ajouter un commentaire
To unscrew the chain side pedal twist the the wrench counter  clockwise. To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
  • To unscrew the chain side pedal twist the the wrench counter clockwise.
  • To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
Continue turning the wrench until the pedal detaches from the crank arm.
  • Continue turning the wrench until the pedal detaches from the crank arm.
William Beechinor
Membre depuis le 26/09/2012
109 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-49, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 17
Total : 1,205
