Aller au contenu principal
How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster
Ce dont vous avez besoin
  1. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster, How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 1, image 1 de 1
    • Remove all five 5mm Phillips #1 screws from the bottom of the toaster.
  2. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 2, image 1 de 1
    • Lift the top of the toaster from the bottom section of the toaster.
    • Do this carefully so that you don't damage the switch board.
  3. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 3, image 1 de 1
    • Look into the toaster and locate the two divots that the support bracket has detached from.
  4. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 4, image 1 de 2 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 4, image 2 de 2
    • Locate the detached support bracket.
    • From the back of the toaster (the side opposite the side of the toasting lever), you will see the broken support bracket sticking out.
  5. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 5, image 1 de 3 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 5, image 2 de 3 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 5, image 3 de 3
    • Use the portion of the bracket that is sticking out of the back of the toaster to move the support bracket.
    • Align the support bracket with the two divots on the moving bracket assembly.
    • In this particular model, the shell of the toaster cannot be completely removed. It might be helpful to have a helper hold up the shell of the toaster so that it is not in your way.
  6. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 6, image 1 de 1
    • Using moderate force, push the teeth of the support bracket into the divots on the moving bracket assembly.
    • If the teeth on the support bracket are damaged, further repair might be necessary in order for them to fit into the divots.
  7. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 7, image 1 de 2 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 7, image 2 de 2
    • Carefully lower the shell of the toaster back down to its base.
    • Lift and lower the toasting lever a few times to ensure that the support bracket is firmly in place.
  8. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 8, image 1 de 1
    • Screw on the bottom of the toaster using all five 5mm Phillips #1 screws.
Follow these steps and your toaster will be as good as new!
Tori Mobley
Membre depuis le 02/20/18
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 2,281
