Aller au contenu principal
How to Reduce MacBook Pro Core Temperature
Ce dont vous avez besoin
  1. How to Reduce MacBook Pro Core Temperature, Dissassembly: étape 1, image 1 de 1
    • First off you'll need to locate a disassembly guide for your machine and follow it carefully to remove the logic board.
    • If you haven't already, this would be a good opportunity to follow a guide for replacing the thermal paste.
  2. How to Reduce MacBook Pro Core Temperature, Thermally bonding the heatsinks: étape 2, image 1 de 3 How to Reduce MacBook Pro Core Temperature, Thermally bonding the heatsinks: étape 2, image 2 de 3 How to Reduce MacBook Pro Core Temperature, Thermally bonding the heatsinks: étape 2, image 3 de 3
    • The aim here is to sandwich thick thermal pads under you MacBook's heatsinks to contact the upper case, and atop them to contact the bottom cover. This will help conduct heat away from the machine by effectively making the entire unibody one big heatsink.
    • On my machine, a mid-2010 15 inch MBP, I needed to use three strips of a 2mm thick thermal pad under the centre heatsink, two strips under the side one and one strip atop each to make contact with the bottom cover.
    • Try to use enough layers that the heatsinks are in good contact, but not so many that anything needs to bend to fit back.
Now reassemble your MacBook by following the disassembly guide in reverse-order. Always monitor your system's temperatures before running any heavy applications just in case something went wrong.
15 autres ont terminé cette réparation.
Dan
Membre depuis le 10/22/14
2 274 Réputation
3 tutoriels rédigés
Un commentaire
This ist crazy.
Went from 55 idle to 30 idle and a top end of 83°c instead of throttling.
(13” retina macbook pro)
Peter Nemeth - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 31
30 derniers jours : 110
Total : 15,256
