Aller au contenu principal
How to Remove a Car Stereo in a Chevy Tracker
Ce dont vous avez besoin
  1. How to Remove a Car Stereo in a Chevy Tracker, How to Remove a Car Stereo in a Chevy Tracker: étape 1, image 1 de 2 How to Remove a Car Stereo in a Chevy Tracker, How to Remove a Car Stereo in a Chevy Tracker: étape 1, image 2 de 2
    • First, you must disconnect the negative end of the car battery.
    • You will potentially be shocked if you mishandle the battery. Make sure the car is off before inspecting the engine and grabbing the negative connector.
    • Open the hood of your car and locate the battery.
    • Look for the negative end of your battery. It is usually indicated with a minus sign next to it.
    • Disconnecting the negative connection prevents you from receiving any electrical shocks while removing the stereo.
  2. How to Remove a Car Stereo in a Chevy Tracker: étape 2, image 1 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 2, image 2 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 2, image 3 de 3
    • Use a socket wrench to remove the nut that holds the negative connector in place.
    • Place the negative connector away from the battery.
  3. How to Remove a Car Stereo in a Chevy Tracker: étape 3, image 1 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 3, image 2 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 3, image 3 de 3
    • A Chevy Tracker will have a trim that surrounds the stereo.
    • The trim is the black plastic that encompasses the stereo and the small tray/compartment.
    • Remove the screw located on the underside of the trim above the car stereo.
  4. How to Remove a Car Stereo in a Chevy Tracker: étape 4, image 1 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 4, image 2 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 4, image 3 de 3
    • Unscrew the two screws hidden behind the tiny tray/compartment.
    • Afterwards, you can safely remove the trim.
  5. How to Remove a Car Stereo in a Chevy Tracker: étape 5, image 1 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 5, image 2 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 5, image 3 de 3
    • Once the trim is removed, remove the four screws found on each corner of the stereo.
  6. How to Remove a Car Stereo in a Chevy Tracker: étape 6, image 1 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 6, image 2 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 6, image 3 de 3
    • Carefully remove the stereo.
    • Look behind the stereo to see how it is connected.
    • The grouped up, different colored collection of wires connect to the speakers, amplifiers, and stereo buttons depending on the color.
    • The thick, metal wire connects to the car antennae.
    • Don't pull too hard! There are connections to the radio that we need to unplug.
  7. How to Remove a Car Stereo in a Chevy Tracker: étape 7, image 1 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 7, image 2 de 3 How to Remove a Car Stereo in a Chevy Tracker: étape 7, image 3 de 3
    • Unplugging the connections, except for the multicolored group of wires. All are located on the back of stereo should be as simple as pulling on them.
    • "To remove the group of wires", follow the wires until you reach a connector and unplug the connector.
    • The thick, metal wire connecting to the radio antennae can be easily removed by pulling on it.
    • The harness (the grayish female connector circled in red) is what connects the wires to the various components of the car.
  8. How to Remove a Car Stereo in a Chevy Tracker: étape 8, image 1 de 2 How to Remove a Car Stereo in a Chevy Tracker: étape 8, image 2 de 2
    • Some car stereos are attached to a mount.
    • Each mount is similarly installed as the image shows.
    • Remove the screws located on each side of the mount.
  9. How to Remove a Car Stereo in a Chevy Tracker: étape 9, image 1 de 1
    • You have now successfully uninstalled a car stereo from a Chevy Tracker!
    • Do not forget to reconnect the negative connector to the battery when finished!
Following the steps in reverse will reinstall your car stereo. Different car stereos might require extra connections to be installed.
4 autres ont terminé cette réparation.
Nick Eaton
Membre depuis le 09/29/15
211 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-4, Green Fall 2015 Membre de l'équipe Cal Poly, Team 15-4, Green Fall 2015
CPSU-GREEN-F15S15G4
4 membres
4 tutoriels rédigés
Un commentaire
Ended up blowing a fuse for my taillights and dash lights. I replaced fuse, however still not coming back on. Any suggestions as to why?
Brandy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 50
Total : 6,811
