Introduction
Chain tension is important for the proper operation of your bike.
If the chain is too loose, then the derailleur may not function optimally, and the chain isn't as coupled with the bike's gears.
This guide shows you how to tighten your chain by simply nudging the rear wheel farther back in its housing, placing more tension on the chain so that it is no longer loose.
Shift the rear derailleur into its outermost gear, and the front derailleur into its outer gear.
  • Shift the rear derailleur into its outermost gear, and the front derailleur into its outer gear.
Ajouter un commentaire
Open the quick-release lever on the rear axle. Quick-release levers are designed to allow you to remove a wheel by hand, with no tools. Continue to loosen the axle by hand until you can freely move the axle in its notch in the rear fork.
  • Open the quick-release lever on the rear axle.
    • Quick-release levers are designed to allow you to remove a wheel by hand, with no tools.
  • Continue to loosen the axle by hand until you can freely move the axle in its notch in the rear fork.
Move the axle farther back along the notch in the fork so that the chain is taught between the cogs.
  • Move the axle farther back along the notch in the fork so that the chain is taught between the cogs.
    • You might want to ask a friend to help you keep everything steady.
    • Be careful when choosing the new position for the axle; make sure that the wheel will be aligned with the frame.
Now that the axle is placed correctly, re-tighten the axle and re-apply the quick-release as shown in Step 1.
  • Now that the axle is placed correctly, re-tighten the axle and re-apply the quick-release as shown in Step 1.
Tobias Elder
Membre depuis le 25/04/2013
113 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 21-53, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 527
