Introduction
If your brakes are slowing you down too fast or not fast enough, this guide can help remedy this problem.
Pièces
Aucune pièce nécessaire.
While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench. While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
  • While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
Ajouter un commentaire
If you need to loosen your brakes, pull up on the arm while holding the brake cable in place.
  • If you need to loosen your brakes, pull up on the arm while holding the brake cable in place.
  • To tighten your brakes follow the above step, except push down on the arm instead of pulling up.
Tighten the screw on the desired location along the cable with the same 5mm allen wrench.
  • Tighten the screw on the desired location along the cable with the same 5mm allen wrench.
You may need to repeat this process until your desired tension is achieved (trial and error).
Ben Hartinger
Membre depuis le 27/01/2014
340 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 1-37, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 208
