Pièces
Aucune pièce nécessaire.
Using a Philips screwdriver, remove the two screws on the top of the device, towards the back.
  • Using a Philips screwdriver, remove the two screws on the top of the device, towards the back.
Ajouter un commentaire
Remove the plastic cover by pulling up on the back and away from the faceplate. Remove the plastic cover by pulling up on the back and away from the faceplate.
  • Remove the plastic cover by pulling up on the back and away from the faceplate.
Remove the faceplate by unclipping the latches on the bottom of the device. Once it's unlatched, pull the faceplate off. Once it's unlatched, pull the faceplate off.
  • Remove the faceplate by unclipping the latches on the bottom of the device.
  • Once it's unlatched, pull the faceplate off.
Now that the device is open, you can check for any blown fuses that may need to be replaced.
  • Now that the device is open, you can check for any blown fuses that may need to be replaced.
Taryn
Membre depuis le 15/09/2011
103 Réputation
4 tutoriels rédigés
Équipe
University of Maine, Team 1-2, Diaz Fall 2011 Membre de l'équipe University of Maine, Team 1-2, Diaz Fall 2011
UMAINE-DIAZ-F11S1G2
2 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 764
