Introduction
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
Pièces
Aucune pièce nécessaire.
  • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
  • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
Ajouter un commentaire
Pull up on the tab to remove the batteries.
  • Pull up on the tab to remove the batteries.
  • Note: The batteries will probably fall out of their holder.
Your camera should look something like this.
  • Your camera should look something like this.
  • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
All cleaned up!
  • All cleaned up!
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
Zachary Phillips
Membre depuis le 08/04/2011
178 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-26, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 membres
6 tutoriels rédigés
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 82
Total : 10,955
