Pièces
Aucune pièce nécessaire.
Before starting, be sure to remove the battery from the camera. See Removing the Olympus Stylus 760 Battery Guide for details.
Ajouter un commentaire
Remove the screw located on the right side of the camera
  • Remove the screw located on the right side of the camera
Remove the two screws from the left side of the camera
  • Remove the two screws from the left side of the camera
Use a small prying device to delicately separate the front casing from the back.
New line.
  • Use a small prying device to delicately separate the front casing from the back.
New line.
    • When separating the 2 cases be cautious of the silver band and buttons that located in the middle of the camera. They will come loose.
Remove the 2 screws on the right side of the camera. Remove the 2 screwson the left side of the camera CAUTION! Circuit ribbon is attached at the top left of the camera be careful when separating the front and back of the camera after removing the 4 screws.
  • Remove the 2 screws on the right side of the camera.
  • Remove the 2 screwson the left side of the camera
  • CAUTION! Circuit ribbon is attached at the top left of the camera be careful when separating the front and back of the camera after removing the 4 screws.
Carefully flip up the clip attaching the ribbon from the rear to the front and pull it out
  • Carefully flip up the clip attaching the ribbon from the rear to the front and pull it out
Carefully separate the front and back of the camera
  • Carefully separate the front and back of the camera
You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
Using a size 0 Phillips head, remove 3 screws holding the ribbon cable that covers the back of the lens.
  • Using a size 0 Phillips head, remove 3 screws holding the ribbon cable that covers the back of the lens.
  • CAUTION: small loose pieces under the back lens cover
Using tweezers remove tiny square lens cases.  There are 4 small pieces.
  • Using tweezers remove tiny square lens cases. There are 4 small pieces.
  • The pieces are relatively small, so becareful that they do not fall inside of the lens.
Remove the larger black rubber frame. Clean with condensed air.
  • Remove the larger black rubber frame. Clean with condensed air.
Derek Guzman
Membre depuis le 10/02/2012
17 Réputation
1 tutoriel rédigé
Équipe
James Madison, Team 3-3, Klein Spring 2012 Membre de l'équipe James Madison, Team 3-3, Klein Spring 2012
JMU-KLEIN-S12S3G3
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 18
Total : 1,139
