Fold fine grit sand paper over a credit card.
  • Fold fine grit sand paper over a credit card.
Ajouter un commentaire
Rub credit card with sand paper up and down vertically inside the game cartridge port.
  • Rub credit card with sand paper up and down vertically inside the game cartridge port.
Blow out game cartridge port using a can of compressed air.
  • Blow out game cartridge port using a can of compressed air.
  • Warning: Do not turn the aerosol can upside down as you spray.
Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
  • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
Ligne d'arrivée
8 autre(s) ont terminé cette réparation.
Erik Bjornstrom
Membre depuis le 04/10/2010
650 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 3-29, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 membres
5 tutoriels rédigés
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - Réponse
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 49
30 derniers jours : 205
Total : 20,062
