Aller au contenu principal
How to clean your Panasonic SA-HT810V VCR heads
Ce dont vous avez besoin
  1. How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: étape 1, image 1 de 3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: étape 1, image 2 de 3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: étape 1, image 3 de 3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. How to clean your Panasonic SA-HT810V VCR heads: étape 2, image 1 de 2 How to clean your Panasonic SA-HT810V VCR heads: étape 2, image 2 de 2
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the 12 screws highlighted by the red circles in image one.
  3. How to clean your Panasonic SA-HT810V VCR heads: étape 3, image 1 de 1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. How to clean your Panasonic SA-HT810V VCR heads: étape 4, image 1 de 3 How to clean your Panasonic SA-HT810V VCR heads: étape 4, image 2 de 3 How to clean your Panasonic SA-HT810V VCR heads: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Microfiber Cleaning Cloths
    $3.99
    J'achète
    • Before cleaning the VCR heads, be sure that the front of the device is facing you with the top cover removed.
    • Locate the two VCR heads highlighted in by the blue boxes in image one.
    • GENTLY clean heads with a microfiber rag and a cleaning solution of your choice.
2 autres ont terminé cette réparation.
Nathan Cheadle
Membre depuis le 04/15/10
161 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 16-5, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 29
Total : 2,697
