Introduction
If your Sony Xperia Z3 smartphone shows no image but the backlight is working, there may be a problem with the phone’s logic board. This problem can occur because of failed screen replacement attempts. Use this guide to repair your device.
Alternatively, see this Sony Xperia Z3 no image after screen replacement YouTube video for help micro-soldering the logic board.
Ce dont vous avez besoin
Vidéo d'introduction
Sony Z3 no image after screen replacement only backlight Hardware Repair
Heat the back cover of your Xperia Z3 to loosen the adhesive underneath.
Lift up the back cover with a suction handle and put an opening pick in the gap.
Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
Unplug the battery flex connector.
Use a tweezer to gently pull off the adhesive strip on the bottom part of the battery.
Use your fingers or the flat end of a spudger to unclip the cables holding the logic board in place.
2 commentaires
I have a z3 single, it turns on the backlight but not the image what to do? procedure above did not work …
i &&^&@@ my display
