Pièces
Aucune pièce nécessaire.
Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
Ajouter un commentaire
Turn the computer upside down on a flat surface.
  • Turn the computer upside down on a flat surface.
Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery. Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery. Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Lift the battery from the middle and then pivot it outward to remove it from the comp. Lift the battery from the middle and then pivot it outward to remove it from the comp.
  • Lift the battery from the middle and then pivot it outward to remove it from the comp.
Remove the bezel by prying it away from the screen using the spudger. Remove the bezel by prying it away from the screen using the spudger.
  • Remove the bezel by prying it away from the screen using the spudger.
Remove the four 3mm PH1 Phillips head screws in each corner of the screen and do not care about outer screws.
  • Remove the four 3mm PH1 Phillips head screws in each corner of the screen and do not care about outer screws.
Remove the screen and place the screen very softly on the keyboard.
  • Remove the screen and place the screen very softly on the keyboard.
Remove the sticker gently and disconnect the metal blade. Remove the sticker gently and disconnect the metal blade.
  • Remove the sticker gently and disconnect the metal blade.
Brandon
Membre depuis le 23/03/2018
607 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G3, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S2G3
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 6
Total : 23
