My friend gave me it for 5€ (broken lcd and touch) so i took it apart
  • My friend gave me it for 5€ (broken lcd and touch) so i took it apart
  • Yours may look different but tutorial like this should help you anyway :)
Ajouter un commentaire
That's back of Huawei ascend g510
  • That's back of Huawei ascend g510
  • It's Inexpensive android phone
  • To open pry left down corner
  • You don't need any tools for this... You can pry any corner to pop the back open
First remove battery
  • First remove battery
It's HB4W1H 3.7v 1750mAh (6.5Wh) Li-ion battery Don't mess with Lithium ion batteries... (And don't take apart)
  • It's HB4W1H 3.7v 1750mAh (6.5Wh) Li-ion battery
  • Don't mess with Lithium ion batteries... (And don't take apart)
  • MADE IN CHINA... As everything
There are
  • There are
  • 7 black T5 screws
  • 1 white T5 screw
  • 1 black Philipps #0 screw
  • Just remove all and sort them so you don't mix them
There are many clips along the sides
  • There are many clips along the sides
  • Don't pry to hard or you'll break some plastic
  • These clips really suck
First undo all connectors (lcd, touch, camera, sim/sd slot)
  • First undo all connectors (lcd, touch, camera, sim/sd slot)
  • Main PCB is hold with clips and glue
  • Really frustrating to remove it... Glue or clips are everywhere
That's the camera
  • That's the camera
Let's take look at pcb. Unmodular and crusty... I don't like it at all
  • Let's take look at pcb.
  • Unmodular and crusty... I don't like it at all
As bad as front As bad as front
  • As bad as front
To separate glass (with touch)  just heat it up to loosen adhesive To separate glass (with touch)  just heat it up to loosen adhesive
  • To separate glass (with touch) just heat it up to loosen adhesive
16 autre(s) ont terminé cette réparation.
Mateusz Bonkowski
Membre depuis le 20/10/2014
1 168 Réputation
2 tutoriels rédigés
It just won't read my sim card,i was wondering if there is a setting that has been changed?
Michael Cummins - Réponse
I have a good idea of what you are doing and how much you are doing. I have a nice day ahead of the individual named recipient
Dear sir
My phone huawei G510 runs but the display light is not coming please can u give me some suggestion how to repair it
sak - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 63
Total : 4,087
