Introduction
Replace your phone's Micro-USB flex cable to fix any charging issues.
Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack. Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack.
  • Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack.
Ajouter un commentaire
Insert the pin into the SIM card opening located on the right-side of the phone. Gently push in until the SIM card clicks, and then pull the pin and SIM card out.
  • Insert the pin into the SIM card opening located on the right-side of the phone.
  • Gently push in until the SIM card clicks, and then pull the pin and SIM card out.
  • Repeat this process for the additional SIM card.
Firmly push down on the black plastic covering at the bottom of the phone, and pull down. You may need a sharp thin object to get underneath the plastic.
  • Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
  • You may need a sharp thin object to get underneath the plastic.
Rotate the phone 180 degrees so that the bottom of the phone is now facing up. Firmly push up on the back panel with your thumbs.
  • Rotate the phone 180 degrees so that the bottom of the phone is now facing up.
  • Firmly push up on the back panel with your thumbs.
  • Lift up the back panel from the top right corner and gently pull it away from the phone.
Remove the following screws securing the logic board to the main frame: Five 2mm Phillips #000 screws Two 2.5mm Phillips #000 screws
  • Remove the following screws securing the logic board to the main frame:
    • Five 2mm Phillips #000 screws
    • Two 2.5mm Phillips #000 screws
Push down the yellow plastic lining at the top of the battery and remove the two 2.5mm Phillips #000 screws. Push down the yellow plastic lining at the top of the battery and remove the two 2.5mm Phillips #000 screws.
  • Push down the yellow plastic lining at the top of the battery and remove the two 2.5mm Phillips #000 screws.
Use the flat end of a spudger to gently snap open the first clip located on the the right arm of the retaining plate. Use the flat end of a spudger to gently snap the second clip located on the left arm of the retaining plate. Use the flat end of a spudger to gently lift the upper retaining plate from the phone.
  • Use the flat end of a spudger to gently snap open the first clip located on the the right arm of the retaining plate.
  • Use the flat end of a spudger to gently snap the second clip located on the left arm of the retaining plate.
  • Use the flat end of a spudger to gently lift the upper retaining plate from the phone.
Use the pointy end of a spudger to pry the antenna connector off of its socket. Upon reassembly, you will hear a "click" that indicates the pin has been properly reconnected. Upon reassembly, you will hear a "click" that indicates the pin has been properly reconnected.
  • Use the pointy end of a spudger to pry the antenna connector off of its socket.
  • Upon reassembly, you will hear a "click" that indicates the pin has been properly reconnected.
Use the pointy end of a spudger to gently pry the following connectors out of their sockets: silver LCD cable connector silver Headphone jack cable connector
  • Use the pointy end of a spudger to gently pry the following connectors out of their sockets:
    • silver LCD cable connector
    • silver Headphone jack cable connector
Use the pointy end of a spudger to gently pry the following connectors out of their sockets. Sliver Micro-USB cable connector Copper battery cable connector
  • Use the pointy end of a spudger to gently pry the following connectors out of their sockets.
    • Sliver Micro-USB cable connector
    • Copper battery cable connector
Be careful not to bend, puncture, or crush the battery, even if it is being replaced. The battery can potentially release toxic and flammable chemicals. Use a plastic opening tool to gently lift up the battery from the bottom end.
  • Be careful not to bend, puncture, or crush the battery, even if it is being replaced. The battery can potentially release toxic and flammable chemicals.
  • Use a plastic opening tool to gently lift up the battery from the bottom end.
  • You may need to loosen the adhesive under the battery with slow sawing motions.
Remove the two 2mm Phillips #000 screws securing the copper flex cable to the silver metal tab. The screw on the left has white paint on the top. Chipping the paint will void any warranty you have for your phone.
  • Remove the two 2mm Phillips #000 screws securing the copper flex cable to the silver metal tab.
  • The screw on the left has white paint on the top. Chipping the paint will void any warranty you have for your phone.
In my new Back Battery cover case there is no possibility to screwing the silver metal tab with these 2 screws to securing the copper flex cable . I only can put the silver metal tab with adhesives (double side tape)
clbr - Réponse
Wedge the flat end of a spudger underneath the bottom left of the metal tab. Run the spudger along the bottom edge of the metal tab and gently pry upward. Adhesive under the metal tab will make lifting the tab slightly tedious. The adhesive will come off as long as you gently run the spudger along the bottom of the tab.
  • Wedge the flat end of a spudger underneath the bottom left of the metal tab.
  • Run the spudger along the bottom edge of the metal tab and gently pry upward.
  • Adhesive under the metal tab will make lifting the tab slightly tedious. The adhesive will come off as long as you gently run the spudger along the bottom of the tab.
Gently lift the flex cable from the top-right corner.
  • Gently lift the flex cable from the top-right corner.
  • Do not use excessive force when removing the flex cable. Doing so may tear the cable.
Use tweezers to lift the rubber alignment tab out of its frame. Use tweezers to lift the rubber alignment tab out of its frame. Use tweezers to lift the rubber alignment tab out of its frame.
  • Use tweezers to lift the rubber alignment tab out of its frame.
Chase Hemming
Membre depuis le 14/10/2014
2 373 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 4-44, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 4-44, Amido Fall 2014
CPSU-AMIDO-F14S4G44
5 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 45
Total : 2,511
