Introduction
Use this guide to replace the front facing camera in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
Pièces
Aucune pièce nécessaire.
Switch off your phone. Remove the two Pentalobe P2 screws at the bottom. Remove the SIM card tray.
  • Switch off your phone.
  • Remove the two Pentalobe P2 screws at the bottom.
  • Remove the SIM card tray.
Ajouter un commentaire
Insert a plastic opening tool between the display and the case starting at the bottom area of your phone. Carefully pry the display with its parts out of the case. After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
  • Carefully pry the display with its parts out of the case.
  • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover. Swing open the phone backwards.
  • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
  • Swing open the phone backwards.
  • Use a spudger to disconnect the cable.
The cable is for the standby and volume buttons, not for the fingerprint sensor!
JaL - Réponse
Thanks JaL, of course it is.
Tobias Isakeit -
Remove the Phillips #000 screw. Use tweezers to remove the metal plate. Use a spudger to disconnect the battery flex cable.
  • Remove the Phillips #000 screw.
  • Use tweezers to remove the metal plate.
  • Use a spudger to disconnect the battery flex cable.
Use tweezers to carefully loosen the bottom end of the adhesive strip, that holds down the flex connector of the front facing camera. Use a spudger to disconnect the flex cable of the front facing camera. Carefully remove the front facing camera.
  • Use tweezers to carefully loosen the bottom end of the adhesive strip, that holds down the flex connector of the front facing camera.
  • Use a spudger to disconnect the flex cable of the front facing camera.
  • Carefully remove the front facing camera.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
Membre depuis le 23/11/2016
12 850 Réputation
247 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
114 membres
5 894 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 25
Total : 189
