Aller au contenu principal
Huawei P10 Headphone Jack Replacement
Ce dont vous avez besoin
  1. Huawei P10 Headphone Jack Replacement, Back Cover: étape 1, image 1 de 3 Huawei P10 Headphone Jack Replacement, Back Cover: étape 1, image 2 de 3 Huawei P10 Headphone Jack Replacement, Back Cover: étape 1, image 3 de 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Headphone Jack Replacement: étape 2, image 1 de 3 Huawei P10 Headphone Jack Replacement: étape 2, image 2 de 3 Huawei P10 Headphone Jack Replacement: étape 2, image 3 de 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Headphone Jack Replacement: étape 3, image 1 de 2 Huawei P10 Headphone Jack Replacement: étape 3, image 2 de 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Headphone Jack Replacement, Battery disconnect: étape 4, image 1 de 3 Huawei P10 Headphone Jack Replacement, Battery disconnect: étape 4, image 2 de 3 Huawei P10 Headphone Jack Replacement, Battery disconnect: étape 4, image 3 de 3
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Huawei P10 Headphone Jack Replacement, Headphone Jack: étape 5, image 1 de 2 Huawei P10 Headphone Jack Replacement, Headphone Jack: étape 5, image 2 de 2
    • Remove the three Phillips #00 screws.
  6. Huawei P10 Headphone Jack Replacement: étape 6, image 1 de 2 Huawei P10 Headphone Jack Replacement: étape 6, image 2 de 2
    • Use the flat end of a spudger to disconnect the headphone jack.
    • Remove the headphone jack.
    • There is a small piece of adhesive underneath, so it might be a little bit sticky. You can use an iOpener to loosen the adhesive and make the removal easier.
    • When reassembling apply new adhesive where it's necessary.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
2 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
202 809 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 732 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 2,904
