Aller au contenu principal
Huawei P10 Lite Rear Camera Replacement
Ce dont vous avez besoin
  1. Huawei P10 Lite Rear Camera Replacement, Back cover: étape 1, image 1 de 3 Huawei P10 Lite Rear Camera Replacement, Back cover: étape 1, image 2 de 3 Huawei P10 Lite Rear Camera Replacement, Back cover: étape 1, image 3 de 3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Rear Camera Replacement: étape 2, image 1 de 3 Huawei P10 Lite Rear Camera Replacement: étape 2, image 2 de 3 Huawei P10 Lite Rear Camera Replacement: étape 2, image 3 de 3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Rear Camera Replacement: étape 3, image 1 de 2 Huawei P10 Lite Rear Camera Replacement: étape 3, image 2 de 2
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Rear Camera Replacement: étape 4, image 1 de 2 Huawei P10 Lite Rear Camera Replacement: étape 4, image 2 de 2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Rear Camera Replacement, Battery Disconnection: étape 5, image 1 de 3 Huawei P10 Lite Rear Camera Replacement, Battery Disconnection: étape 5, image 2 de 3 Huawei P10 Lite Rear Camera Replacement, Battery Disconnection: étape 5, image 3 de 3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Rear Camera Replacement, Rear Camera: étape 6, image 1 de 2 Huawei P10 Lite Rear Camera Replacement, Rear Camera: étape 6, image 2 de 2
    • Use the flat end of a spudger to disconnect the rear camera flex cable.
    • Remove the rear camera.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
Membre depuis le 11/23/16
202 579 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 722 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 2,125
