Introduction
Although the display of the P10 carries all the parts and calls for an extensive repair when it brakes, all other repairs are fairly simple.
Fancy toolbox style packaging. Front and back reference photos. Front and back reference photos.
  • Fancy toolbox style packaging.
  • Front and back reference photos.
Ajouter un commentaire
Two Pentalobe P2 screws on the bottom. Remove the SIM card.
  • Two Pentalobe P2 screws on the bottom.
  • Remove the SIM card.
Prying the case open with a plastic opening tool. The fingerprint sensor ist still connected to the motherboard. The fingerprint sensor ist still connected to the motherboard.
  • Prying the case open with a plastic opening tool.
  • The fingerprint sensor ist still connected to the motherboard.
The fingerprint sensor can be unplugged easily with a spudger. Two metal brackets—one of the screws covered with a liquid indicator—secure the battery and interconnect cables as well as the display cable. Two metal brackets—one of the screws covered with a liquid indicator—secure the battery and interconnect cables as well as the display cable.
  • The fingerprint sensor can be unplugged easily with a spudger.
  • Two metal brackets—one of the screws covered with a liquid indicator—secure the battery and interconnect cables as well as the display cable.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
The battery is held in place by two adhesive strip of which one of them has a pull tab for easy removal. The battery is held in place by two adhesive strip of which one of them has a pull tab for easy removal.
  • The battery is held in place by two adhesive strip of which one of them has a pull tab for easy removal.
The loudspeaker is glued in place with a mild adhesive. With the metal shield removed we can unplug the interconnect cable, the antenna cable and the headphone connector. The headphone jack and the daughterboard come out easily.
  • The loudspeaker is glued in place with a mild adhesive.
  • With the metal shield removed we can unplug the interconnect cable, the antenna cable and the headphone connector.
  • The headphone jack and the daughterboard come out easily.
  • The vibrator is held in place by a mild adhesive.
Both cameras are easy to remove. The connector of the  dual camera is secured by a metal bracket. Both cameras are easy to remove. The connector of the  dual camera is secured by a metal bracket.
  • Both cameras are easy to remove. The connector of the dual camera is secured by a metal bracket.
Three more Phillips screws hold the motherboard in place. The earpiece speaker and the proximity and brightness sensor are fixed by mild adhesives. The earpiece speaker and the proximity and brightness sensor are fixed by mild adhesives.
  • Three more Phillips screws hold the motherboard in place.
  • The earpiece speaker and the proximity and brightness sensor are fixed by mild adhesives.
The power and volume button bracket can be removed very easily with a tweezers.
  • The power and volume button bracket can be removed very easily with a tweezers.
With a little bit of heating one of the display corners can be lifted with an opening pick. The adhesive on the side is cut with a halberd spudger. Now the display cable can be thread through the frame.
  • With a little bit of heating one of the display corners can be lifted with an opening pick.
  • The adhesive on the side is cut with a halberd spudger.
  • Now the display cable can be thread through the frame.
The Huawei P10 earns a 6 out of 10 on our repairability scale (10 is the easiest to repair): Many components are modular and can be replaced independently.
  • The Huawei P10 earns a 6 out of 10 on our repairability scale (10 is the easiest to repair):
    • Many components are modular and can be replaced independently.
    • Only standard Phillips screws are used.
    • Except for the two Pentalobe screws on the bottom.
    • The battery can be replaced after removing a few cables and has a pull tab on one adhesive strip.
    • Components are adhered to the back of the fused display.
Ligne d'arrivée
Tobias Isakeit
Membre depuis le 31/03/2014
25 014 Réputation
203 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
114 membres
5 900 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 95
Total : 1,295
