Introduction
Use this guide to replace the vibration motor in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
Pièces
Aucune pièce nécessaire.
Switch off your phone. Remove the two Pentalobe P2 screws at the bottom. Remove the SIM card tray.
  • Switch off your phone.
  • Remove the two Pentalobe P2 screws at the bottom.
  • Remove the SIM card tray.
Ajouter un commentaire
Insert a plastic opening tool between the display and the case starting at the bottom area of your phone. Carefully pry the display with its parts out of the case. After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
  • Carefully pry the display with its parts out of the case.
  • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover. Swing open the phone backwards.
  • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
  • Swing open the phone backwards.
  • Use a spudger to disconnect the cable.
The cable is for the standby and volume buttons, not for the fingerprint sensor!
JaL - Réponse
Thanks JaL, of course it is.
Tobias Isakeit -
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the Phillips #00 screw. Use tweezers to remove the metal plate. Use a spudger to disconnect the battery flex cable.
  • Remove the Phillips #00 screw.
  • Use tweezers to remove the metal plate.
  • Use a spudger to disconnect the battery flex cable.
Remove the four Phillips #00 screws. Use Tweezers to remove the metal plate.
  • Remove the four Phillips #00 screws.
  • Use Tweezers to remove the metal plate.
Use a spudger to disconnect the main flex cable. Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
  • Use a spudger to disconnect the main flex cable.
  • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
Use a spudger to disconnect the headphone jack and the loudspeaker flex cables. Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
  • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
Do not damage any components sitting on the charging board while removing it. Use a spudger to pry out the charging board.
  • Do not damage any components sitting on the charging board while removing it.
  • Use a spudger to pry out the charging board.
  • Remove the charging board.
Use tweezers to remove the vibration motor.
  • Use tweezers to remove the vibration motor.
    • There is some adhesive underneath the vibration motor and its flex cable. You can use an iOpener to loosen the adhesive and make the removal easier.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
Membre depuis le 23/11/2016
12 960 Réputation
248 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
114 membres
5 923 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 24
Total : 171
