Introduction
Use this guide if your Huawei Union’s camera is not working properly, photos are obstructed or unclear.
Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
  • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
Ajouter un commentaire
Use the flat end of a spudger, or fingernail, to lift up the battery and pull out. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
  • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the thirteen 3mm Phillips #00 screws from the back panel.
  • Remove the thirteen 3mm Phillips #00 screws from the back panel.
Use the flat end of a spudger to pry off the back panel.
  • Use the flat end of a spudger to pry off the back panel.
Brittany Achor
Membre depuis le 14/02/2018
651 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 42
