Introduction
Use this guide if your Huawei Union’s speaker will not play sound while watching videos or listening to music.
Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
  • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
Ajouter un commentaire
Use the flat end of a spudger, or fingernail, to lift up the battery and pull out. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
  • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the thirteen 3mm Phillips #00 screws from the back panel.
  • Remove the thirteen 3mm Phillips #00 screws from the back panel.
Use the flat end of a spudger to pry off the back panel.
  • Use the flat end of a spudger to pry off the back panel.
Use the flat end of a spudger to lift the speaker out of the frame and remove.
  • Use the flat end of a spudger to lift the speaker out of the frame and remove.
Brittany Achor
Membre depuis le 14/02/2018
651 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 36
