Pièces
Aucune pièce nécessaire.
Take off the back covering of the phone along with the battery and SIM card. The SIM card is located above the battery.
  • Take off the back covering of the phone along with the battery and SIM card.
  • The SIM card is located above the battery.
Ajouter un commentaire
Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone. Save the screws. They will be needed for reassembly.
  • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
  • Save the screws. They will be needed for reassembly.
Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
  • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
  • NOTE: Save the screws. They will be needed for reassembly.
Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
  • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
  • Note: The power and volume buttons will fall out of the phone. Set aside for reassembly.
Carefully pull the backing of the phone from the motherboard with your hands.
  • Carefully pull the backing of the phone from the motherboard with your hands.
2 autre(s) ont terminé cette réparation.
Savanah Anik
Membre depuis le 13/02/2014
53 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-1, Meza Spring 2014 Membre de l'équipe Ohio State, Team 1-1, Meza Spring 2014
OSU-MEZA-S14S1G1
4 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 312
