Pièces
Aucune pièce nécessaire.
Flip the ThinkPad over so that it is upside down. Push latch switch to the left.
  • Flip the ThinkPad over so that it is upside down.
  • Push latch switch to the left.
  • Gently lift the battery out and away from the ThinkPad
  • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
Ajouter un commentaire
The sticker is to keep the warranty on the laptop so once removed the warranty is void Peel the sticker and remove the 15mm screw Remove all 6 of the 16mm screws
  • The sticker is to keep the warranty on the laptop so once removed the warranty is void
  • Peel the sticker and remove the 15mm screw
  • Remove all 6 of the 16mm screws
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
use a  prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
  • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
Lift the keyboard and remove the keyboard ribbon cable  from the laptop Lift the keyboard and remove the keyboard ribbon cable  from the laptop Lift the keyboard and remove the keyboard ribbon cable  from the laptop
  • Lift the keyboard and remove the keyboard ribbon cable from the laptop
2 autre(s) ont terminé cette réparation.
Matheus
Membre depuis le 19/03/2018
128 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G2, Bernier Spring 2018
UMASSD-BERNIER-S18S2G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 36
