Aller au contenu principal
IBM ThinkPad T42 Mini-PCI Port Replacement
Ce dont vous avez besoin
  1. IBM ThinkPad T42 Mini-PCI Port Replacement, Bottom cover: étape 1, image 1 de 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Mini-PCI Port Replacement, Rear screws: étape 2, image 1 de 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Mini-PCI Port Replacement, Keyboard and Trackpad: étape 3, image 1 de 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Mini-PCI Port Replacement: étape 4, image 1 de 2 IBM ThinkPad T42 Mini-PCI Port Replacement: étape 4, image 2 de 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Bracket: étape 5, image 1 de 1
    • Remove the screw affixing the bracket down.
  6. IBM ThinkPad T42 Mini-PCI Port Replacement, Bracket Removal: étape 6, image 1 de 1
    • Lift the bracket up and out.
  7. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Removal: étape 7, image 1 de 1
    • Carefully disconnect it from the motherboard and pull it out of the device.
Gerald Watanabe
Membre depuis le 04/14/10
279 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 29-76, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 membres
35 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 5
Total : 4,395
