Introduction
Batteries may lose the ability to hold a complete charge or stop working. This guide will show you how to remove and replace the Battery.
Place one hand on the battery and the other on the unlock switch. Slide the switch to the left to unlock the battery.
  • Place one hand on the battery and the other on the unlock switch.
  • Slide the switch to the left to unlock the battery.
  • Hold the switch to the left because if you let go, it will lock again.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Gently pull the battery straight out towards your body. Make sure to pull the battery straight out because pulling it at an angle can cause damage.
  • Gently pull the battery straight out towards your body.
  • Make sure to pull the battery straight out because pulling it at an angle can cause damage.
aLiX pIeRRe
Membre depuis le 19/03/2018
699 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S6-G4, Bernier Spring 2018
UMASSD-BERNIER-S18S6G4
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 19
