Introduction
This guide provides a step-by-step plan for disassembly of the Impuls LED Alarm Clock Radio. The price of the clock radio is relatively low, it is 16.95 euros at bol.com. The guide is made by 5 Industrial Design students at the TU Delft.
Pièces
Aucune pièce nécessaire.
Unscrew the 4 base screws at the bottom with the Phillips 1 screwdriver.
  • Unscrew the 4 base screws at the bottom with the Phillips 1 screwdriver.
Ajouter un commentaire
Open the top and remove the transparent plastic cap. Open the top and remove the transparent plastic cap.
  • Open the top and remove the transparent plastic cap.
Remove the 4 screws  from the PCB.
  • Remove the 4 screws from the PCB.
  • It is desirable to use 3 hands because you have to do 3 jobs: screw, hold the top and hold the bottom.
Remove/unclick 4 plastic buttons. There are 4 different types of buttons.
  • Remove/unclick 4 plastic buttons.
  • There are 4 different types of buttons.
Unscrew 2 screws of the  radio tuning system. Unscrew 2 screws of the  radio tuning system.
  • Unscrew 2 screws of the radio tuning system.
Remove the gear that protects the cap.
  • Remove the gear that protects the cap.
Lift up the small gear.
  • Lift up the small gear.
Lift up  the flexible pin rack.
  • Lift up the flexible pin rack.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the flexible pin rack holder.
  • Remove the flexible pin rack holder.
Remove 3 screws of the big PCB.
  • Remove 3 screws of the big PCB.
Remove the backside of the casing.
  • Remove the backside of the casing.
Remove the grey double gear.
  • Remove the grey double gear.
Remove the switch casing.
  • Remove the switch casing.
Flip the big PCB. Flip the big PCB.
  • Flip the big PCB.
Unscrew 2 screws on the back of the PCB the black gear house.
  • Unscrew 2 screws on the back of the PCB the black gear house.
Remove the black  gear housing.
  • Remove the black gear housing.
Unscrew 2 screws of the electro magnet.
  • Unscrew 2 screws of the electro magnet.
Lift up the electro magnet.
  • Lift up the electro magnet.
Unscrew the cap of the POT meter.
  • Unscrew the cap of the POT meter.
Remove the big black double gear.
  • Remove the big black double gear.
Remove the hot glue of the antenna.
  • Remove the hot glue of the antenna.
Remove all the electrical components by desoldering.
  • Remove all the electrical components by desoldering.
Pascalle van Hemert
Membre depuis le 07/03/2018
325 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 43
