Pièces
Aucune pièce nécessaire.
Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
  • Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
  • To ensure you don't lose any tiny parts during the replacement process, place parts on the white magnetic sheet.
  • Once the screws have been removed, proceed to take off back cover.
Ajouter un commentaire
Now, proceed to lift the battery out and remove it.
  • Now, proceed to lift the battery out and remove it.
Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
  • Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
  • Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary. Pull the motherboard out and down away from the top of the phone.
  • Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary.
  • Pull the motherboard out and down away from the top of the phone.
Lauren
Membre depuis le 13/02/2014
43 Réputation
2 tutoriels rédigés
Équipe
Ohio State, Team 1-4, Buehl Spring 2014 Membre de l'équipe Ohio State, Team 1-4, Buehl Spring 2014
OSU-BUEHL-S14S1G4
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 7
Total : 378
