Aller au contenu principal
Insignia 6-Quart Pressure Cooker Circuit Board Replacement
Ce dont vous avez besoin
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: étape 1, image 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 2, image 1 de 1
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 3, image 1 de 1
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 4, image 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 5, image 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 6, image 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 7, image 1 de 1
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 8, image 1 de 1
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 9, image 1 de 1
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 10, image 1 de 1
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 11, image 1 de 1
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 12, image 1 de 1
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 13, image 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: étape 14, image 1 de 1
    • Remove and replace the circuit board.
5 autres ont terminé cette réparation.
Savannah Webb
Membre depuis le 01/18/18
657 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S12-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 membres
5 tutoriels rédigés
8 commentaires
Where do you purchase the circuit board
Douglas Koons - Réponse
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - Réponse
Please, Where can I buy the electrical circuit?
Mohammed - Réponse
why is my circuit board not fixed to the top like in the diagram
david stanley - Réponse
where can I purchase the circuit board
de27@bellsouth.net - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 3,139
