Introduction
This guide will show the required steps to replace the ice tray on the Insignia Ice Maker.
Remove the 6 screws holding the rear casing on. Remove the rear casing Remove the rear casing
  • Remove the 6 screws holding the rear casing on.
  • Remove the rear casing
Ajouter un commentaire
Remove the 4 screws holding the Ice Tray to the body of the Ice Maker. Remove the 4 screws holding the Ice Tray to the body of the Ice Maker. Remove the 4 screws holding the Ice Tray to the body of the Ice Maker.
  • Remove the 4 screws holding the Ice Tray to the body of the Ice Maker.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Remove the 4 screws holding the Ice Tray from the top. Remove the 4 screws holding the Ice Tray from the top. Remove the 4 screws holding the Ice Tray from the top.
  • Remove the 4 screws holding the Ice Tray from the top.
Lift the Water Pump out of the way Lift the Water Pump out of the way
  • Lift the Water Pump out of the way
Remove the final 2 screws. Remove the final 2 screws. Remove the final 2 screws.
  • Remove the final 2 screws.
Remove the plastic cover from the circuit board by pressing the lever on the side. A pry tool may be required. Disconnect the water tray cord. Disconnect the water tray cord.
  • Remove the plastic cover from the circuit board by pressing the lever on the side. A pry tool may be required.
  • Disconnect the water tray cord.
Evan Taylor
Membre depuis le 18/01/2018
517 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S21-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S21-G3, Banghart Winter 2018
CPSU-BANGHART-W18S21G3
2 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 25
Total : 34
