Aller au contenu principal
Insignia NS-24ER310NA17 Input/Output Cover Replacement
Ce dont vous avez besoin
  1. Insignia NS-24ER310NA17 Input/Output Cover Replacement, Remove the base: étape 1, image 1 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement, Remove the base: étape 1, image 2 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement, Remove the base: étape 1, image 3 de 3
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 2, image 1 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 2, image 2 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 2, image 3 de 3
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the Phillips Head Screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Input/Output Cover Replacement, Pry the TV open: étape 3, image 1 de 1
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Input/Output Cover Replacement, Disconnect wires: étape 4, image 1 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement, Disconnect wires: étape 4, image 2 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement, Disconnect wires: étape 4, image 3 de 3
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 5, image 1 de 1
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
  6. Insignia NS-24ER310NA17 Input/Output Cover Replacement, Motherboard: étape 6, image 1 de 1
    • Remove all strips of tape attached to the silver steel rectangular piece.
  7. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 7, image 1 de 1
    • Pull the red wire out from under the black plastic clip.
  8. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 8, image 1 de 2 Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 8, image 2 de 2
    • Unscrew the four screws surrounding the steel rectangle with a Phillips 00 Screwdriver.
  9. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 9, image 1 de 1
    • Carefully lift the rectangular piece.
  10. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 10, image 1 de 1
    • The rectangular piece will still be attached to the motherboard beneath it with a strip of tape. Remove this strip of tape.
  11. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 11, image 1 de 2 Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 11, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two screws on both sides of the motherboard.
  12. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 12, image 1 de 1
    • Carefully lift the motherboard away from the television.
    • Keep in mind that the motherboard is still attached by several thin wires and should not be tugged.
  13. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 13, image 1 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 13, image 2 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 13, image 3 de 3
    • There are 5 wires attached to the motherboard. Remove the two thicker white wires to the right of the red wire.
  14. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 14, image 1 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 14, image 2 de 3 Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 14, image 3 de 3
    • Remove the remaining three wires from the mainboard.
  15. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 15, image 1 de 1
    • Carefully remove the mainboard from the television.
    • You have now successfully removed the mainboard.
  16. Insignia NS-24ER310NA17 Input/Output Cover Replacement, Input/Output Board Covers: étape 16, image 1 de 2 Insignia NS-24ER310NA17 Input/Output Cover Replacement, Input/Output Board Covers: étape 16, image 2 de 2
    • After following the prerequisite guides, you should have the main board off with the black plastic still on. To remove the plastic, unscrew the nut that holds this plastic to the cable input on the board.
  17. Insignia NS-24ER310NA17 Input/Output Cover Replacement: étape 17, image 1 de 1
    • After removing the nut from the cable input, the black plastic should easily slide off of the inputs on the board. There are two separate pieces of plastic on the board, so be sure to remove both.
Patrick Dillon
Membre depuis le 01/22/18
156 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S16-G2, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G2, Banghart Winter 2018
CPSU-BANGHART-W18S16G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 580
