Introduction
This replacement guide will assist you in motherboard replacement for the Insignia NS-24ER310NA17.
Pièces
Aucune pièce nécessaire.
Place the TV on a surface so that the screen is facing down and you have access to the back.
  • Place the TV on a surface so that the screen is facing down and you have access to the back.
Ajouter un commentaire
Flip the TV upside down so that you have access to the TV base. Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base. Remove the base from the frame.
  • Flip the TV upside down so that you have access to the TV base.
  • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
  • Remove the base from the frame.
Flip the TV back so that the screen is face down Use the Phillips 00 Screwdriver to remove all the Phillips Head Screws from the the backside of the TV.
  • Flip the TV back so that the screen is face down
  • Use the Phillips 00 Screwdriver to remove all the Phillips Head Screws from the the backside of the TV.
Flip the TV so that the top of the TV is on your flat surface.
  • Flip the TV so that the top of the TV is on your flat surface.
  • Gently pry apart the front and back of Tv from one another. The two sides of your TV should be easily pulled apart since there are no longer any screws holding it together.
There are wires still keeping the two sides of TV together, so remove all the pieces of tape to detach the wires from sides. There are wires still keeping the two sides of TV together, so remove all the pieces of tape to detach the wires from sides. There are wires still keeping the two sides of TV together, so remove all the pieces of tape to detach the wires from sides.
  • There are wires still keeping the two sides of TV together, so remove all the pieces of tape to detach the wires from sides.
You should now be able to pry apart your TV so that you have a clear view of the inside on both sides.
  • You should now be able to pry apart your TV so that you have a clear view of the inside on both sides.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove all strips of tape attached to the silver steel rectangular piece.
  • Remove all strips of tape attached to the silver steel rectangular piece.
Pull the red wire out from under the black plastic clip.
  • Pull the red wire out from under the black plastic clip.
Unscrew the four screws surrounding the steel rectangle, which lays on top of the mainboard, with a Phillips 00 Screwdriver. Unscrew the four screws surrounding the steel rectangle, which lays on top of the mainboard, with a Phillips 00 Screwdriver.
  • Unscrew the four screws surrounding the steel rectangle, which lays on top of the mainboard, with a Phillips 00 Screwdriver.
Carefully lift the silver steel rectangular piece.
  • Carefully lift the silver steel rectangular piece.
The silver steel rectangular piece will be attached to the mainboard with a strip of tape. Remove this strip of tape.
  • The silver steel rectangular piece will be attached to the mainboard with a strip of tape. Remove this strip of tape.
Use a Phillips #00 screwdriver to unscrew the two screws on both sides of the motherboard. Use a Phillips #00 screwdriver to unscrew the two screws on both sides of the motherboard.
  • Use a Phillips #00 screwdriver to unscrew the two screws on both sides of the motherboard.
Remove the mainboard from the television carefully.
  • Remove the mainboard from the television carefully.
    • Keep in mind that the main board is still attached by several thin wires and should not be tugged.
Remove the two thicker white wires furthest to the right of the red wire from the mainboard. Remove the two thicker white wires furthest to the right of the red wire from the mainboard. Remove the two thicker white wires furthest to the right of the red wire from the mainboard.
  • Remove the two thicker white wires furthest to the right of the red wire from the mainboard.
Remove the remaining three wires from the mainboard. Remove the remaining three wires from the mainboard. Remove the remaining three wires from the mainboard.
  • Remove the remaining three wires from the mainboard.
Carefully remove the mainboard from the television.
  • Carefully remove the mainboard from the television.
  • You have now successfully removed the mainboard.
Maggie Kuntz
Membre depuis le 22/01/2018
247 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S16-G2, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G2, Banghart Winter 2018
CPSU-BANGHART-W18S16G2
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 23
Total : 69
